Husqvarna YTH18K46 mower with Kawasaki FR600V power issue
dresdenfan
I was getting ready for the season and had to give the mower a jump off an ATV (amps were the same), not sure how but it was cranking then suddenly nothing; no power anywhere and I suspect a fuse blew but cant find them to check.. replaced the battery battery but still nothing. any Ideas or could someone please tell me where the fuses are, I've traced the lines and cant find them so now I was also thinking The solenoid..am I on the right track?
help would be appreciated
On the right side of the tractor there's a panel remove it and the fuse should be close to the starter solenoid below on the frame has a metal clip hard to see
Thanks found it..I was looking for an in-line glass fuse not a blade. Still gonna change the solenoid out though.
