husqvarna YTH 2348
BJG
mower will start to run in reverse then stops. Will run forward ok
Your model is equipped with the Reverse Operation System (ROS) position on the ignition switch. To mow in reverse the switch needs to be turned to the position to the immediate right of the stop position on the switch. See page 8 of the owner's manual for more info. Happy mowing!!
