Husqvarna seat slides out of place
Sgidden
My new Husqvarna riding mower has an adjustable seat. However it keeps sliding out of place. The design on this is not the best. Any advice on how to fix this?
Husky42
I am having the same problem. I posted this just now. Hope some can help. My seat looks like a bolt is missing in the middle slider. I put one in the bolt hole with a washer, but did not help.
rhkraft
Take the the two bolts out. I think they are for shipping. They bend the seat floor plate in the middle causing the back end of the seat plate to bend down creating less engagement with the seat handle ratchet. When you take the bolts out, the plate stays flat and engagement is better. You can see the difference. It worked for me!
Bill5634
I had the same problem even after removing the shipping bolts and washers. The seat would move when i hit a bump in the lawn. I fashioned a lock bracket from a piece of aluminum bar stock. It bolts to the right side slide and has a bent up tooth that goes into the adjustment track. I could not upload a picture.
