HUsqvarna rz5424--cutting problems
polly
RZ5424 has 14 hours and leaves a little tuff of grass. Checked the blades and doe4s not seem to be a problem Mower has three blades. Had a jdeere with three blades and no trouble with uncut grass. Any suggestions or do i just have to live with this. I need to get rid of this problem. Any ideas please and ty. polly
My 2652 does the same thing. If you have the deck flush kit try running the mower and the water for a good period of time maybe you have some build up under the deck.
The deck is clean and blades are sharp. Only 14 hrs. Other people seem to have this problem. Can,t belive there just built like this. My z465 had 3 blades and 62 in. cut and no problems. There has to be a solution.--polly
