Husqvarna RZ4619 tires
dkeener635
I have a Husqvarna RZ4619. The owners manual says to maintain 15psi of pressure in all tires. I understand that for the rear tires, but the front tires appear to be 6 or 8 inch pneumatic slick tires with no treads. If I read on them correctly it has a very low number for max psi. I am afraid to put 15 psi in them. Is it possible there is a mistake in my owners manual that says to maintain 15 psi in all tires?
Thanks in advance for responses...
I would use what is listed on the tire for the maximum tire pressure.
BlazNT
I hate to disagree with someone I trust their opinion on but the reason they say 15 PSI is to level the mower. First, you level the mower then you level the deck. I am sure the max PSI is higher than 15 so you will have no problems at all.
GrassCutter3
hi
I have to agree with BlazNT that :
That's true that ma PSI is higher then 15, so you shouldn't worry at all.
