pz60mMowerman
Husqvarna PZ60 hydro pump bypass valve set up? Should it be 100 closed as the instructions implies? "Tighten the valve moderately."
Because after it was manually moved after turning the bypass valves open >1/2 turn. When I closed them, it was much more than a 1/2 of turn to seat them. They were hand snug no wrench used. What is the correct way to set the bypass valve up? Thanks
