Husqvarna engine issue
Wills7802
Hey guys thanks for the add. Can anyone help? I've got a husky ride on, with a kawasaki Fr600 engine in. Issue is after running for about half and hour it leaks fuel out of the air filter.... then stops abruptly and won't start again for a while. Anyone else had this happen? Tks so much. Any invite would be great. Cheers
The float valve is not cutting off the fuel
Time to pull the carb off & give it a clean.
Scrubcadet10
Moderator
Staff member
Also Check your engine oil for gas dilution.
