Husqvarna Back Pack Blower won't start
cea1
I have a Huqvarna Back Pack Blower, model 125BT that won't start. I using it and it shutoff without a sputter. When it shutoff I knew immediately it hadn't run out of fuel, I assume it had something to do with firing. So, I trying troubleshooting the problem by taking the spark plug out, reattached the spark plug wire, grounded the spark plug the block, pulled the pull-cord and the spark was coming across the electrode, and while pulling the cord I noticed that the fuel vapor from the primer bulb was whirling around in the cylinder-head. Could the ignition coil be faulty? Oh by the way, while checking for spark I turned the power switch on and off intermittently just to be sure it wasn't shorting out. What more can I do to resolve this problem.
