Husqvarna 125 Leaf Blower
C@TCH
Worked perfectly for 4 years then last time I went to use it wouldn't start.
Carb is good,gets fuel, spark is good. Had a guy look at it and said compression is no good,it's only 90. Would replacing the piston ring help or should I replace piston also. Piston looks good,no scores, it was just a bit dirty.
Am I wasting my time and money trying to fix it.
mechanic mark
https://www.google.com/search?sourc...na 125 blower&aqs=chrome..69i57j0l5.25087j0j8
Weigh your money options repair parts vs. price of new blower. You can pick up new Echo at local Home Depot for $160. I have two Echo's, one hand held the other backpack blower. I always use echo 2-cycle oil with high test 93 octane gas, I use high test in all equipment, let us know what you decide & how it runs Husqvarna vs, Echo, thanks.
ECHO 165 mph 391 CFM Low Noise Handheld Gas Blower-PB-250LNAA - The Home Depot
