Husqvarna 1 year old rider wont start
curve31
Mower won't start unless we throw gas in the carb. We replaced the spark plugs, the fuel filter, checked the float ring. It has fresh gas and we used a bottle of fuel treatment. I don't know what else to try. Any thoughts?
gfp55
Maybe you could post the model# serial# Both the engine and mower.
curve31
engine
model-40h777
serial-110928yg22584
mower
model-yth22v46xl8
serial-101211a002392
Make sure the choke is closing all the way. I have seen one Husqvarna and one Craftsman this year with the single throttle/choke control, that wasn't adjusted to close the choke all the way, therefore were hard to start.
curve31
Not sure we know how to check that but we will try. Would like to avoid taking it to a mechanic but its not looking good. Thank you for you advice.
gfp55
Maybe you could check out a Utube video on small engine repair, there is lots of (how to) videos there.
curve31
Ok, so we checked it out and youre right. Its not closing. There is a silver lever that we pushed up and it started right up. So we know the problem we just don't know why or how to fix it. Suggestions?
gregjo1948
Try blocking off the air intake with your hand or a rag to see if it will start before worring about adjusting the choke. gregjo1948
