Walk behind Husqavarna Walk Behind No Reverse
Don Chafin
Husqavarna model 968999120, id W4815A, sn 021200303, 15hp Kawasaki walk behind. Im not sure of the year, but they built them between 2001- 2009. Reverse is barely working with me helping on flat ground only . When I push the brakes foreword with my thumbs it'll back up a little better. It works fine in forward. I was told this may be a oil filter problem in a earlier post. If this is the problem, what do I need to do to fix it? Also could it be something else, Maybe something serious?
