husky tractor mower sputters when blades are engaged
PTC Small Engine
I have a Husqvarna tractor mower that backfires and the engine runs real rough when I engage the blades. If I turn the key to the position to backup with the blades engaged then it smooths right out and runs fine. If I push the clutch in it smooths out and runs fine. Any help would be greatly appreciated.
mechanic mark
sounds like you need a tune-up, adjust valves, oil & filter change, spark plug replacement, air filter, inspect belts for replacement, idler pulleys, grease spindles & all grease fittings, steering sector & pinion gears need grease.
Is it a Twin cylinder ?????
SleeperMower
The reverse safety circuit that kills the engine if you go in reverse with the blades on is likely acting up. I especially think this is true because you said the engine smooths out when you push that button/switch.
