HRX217 Very Hard to Pull Start
tperk100
Mower starts and runs fine, but is very difficult to pull start. What is the likely cause and fix for this?
Thanks much!
Scrubcadet10
Moderator
Staff member
If it has the gcv160 engine, they are known for the exhaust rocker arm to crack and give when it should be opening the exhaust valve.
If thats not the case, I would check your valve clearance.
SKIP to 3:30 for repair
Romore
I acquired a Honda with a similar problem, the clutch was clogged with grass.
tperk100
Thank guys. This dummy here just needed to hold down further on the brake!
CASE CLOSED!
