Anyone else have a problem with the hrr2168vka belt coming off. I paid the dealer $51 and some change to put it back on. Took about five weeks to get it back and second time I used it the belt is off again. Not easy to put it back on either!!
Make sure it is the correct belt. Make sure the belt is in good condition. Check the guides around the crankshaft pulley and the transmission pulley.
The mower is just about new. My wife said it has maybe 4 hours use. So I guess you have had no problem with yours. I'm going to put the belt on once more and let a honda lover own it. We have a small yard and the wife said buy her another electric mower. Thanks and I hope you good luck with your honda. tee3
You know its probably something simple and then your out a 400 dollar mower........
