HRN 216 engine issue?
aardvark
I picked up this HRN 216 used. Couple years old. Guy said it had been recently serviced and had no issues. It started and ran without any problems although he didn't run it long.
After running for 15-20 seconds, the engine stops running smoothly. It pulsates? Drained the (bad) gas, blew out the fuel lines. Changed the spark plug. Changed the oil. The carb doesn't look bad?
We've also just run it, used it to mow, to see if it would warm up out of this. Nope.
Hopefully I can attach a video. Nope, how about a YouTube link?
Nothing is being asked of the mower here. There's a clamp on the blade control handle to keep it running for the video.
What's next?
I found the receipt where Helen Keller serviced it. Yup she is all good.
Clean carb or buy new a OEM. Install new fuel lines from tank to carb. Flush out fuel tank.
Rarely ever go bad. Keep the old one.
Changed the oil.
Okay we are on to something. How about those cooling fins? Not related to your issue but needs investigated.
On the outside maybe. What counts is on the inside.
aardvark
Alright, think I got it. Cleaned the carb per the pinned directions here. Still didn't look bad--maybe the seller tried and missed something? But seems to be running much better. Hooray!
Yeah, right? Certainly not one of my better purchases. Oh well, live and learn.
Back44L&G
It may need a replacement Thermowax cartridge for the Auto Choke system- a surging engine at startup is the primary symptom.
