How to remove seat rod on Z445?
Dan4331
JD Zero Turn MOZ445C012396
Z445
Dead battery and positive cable is bad
I read the seat needs to be removed for access to the battery. How do I remove the rod?
mechanic mark
Ronfron
Z445
Removal of the rod, is not necessary. Simply have a helper tilt the seat at roughly a 45 degree angle. You will then be able to have just enough room to remove the old battery.
