Craftsman Garage
- May 2, 2021
- 45
- 575
To ensure the optimal performance and longevity of your riding lawn mower, regular preventive maintenance is essential. Here are some key maintenance tasks you can perform:
- Regularly check and change the oil: Check the oil level before each use and change the oil as recommended in your owner's manual or approximately every 25 hours of operation. Use the recommended oil type specified by model.
- Clean or replace the air filter: Inspect the air filter regularly and clean or replace it when necessary. A clogged air filter can restrict airflow to the engine, affecting performance. Follow the instructions in your owner's manual for proper cleaning or replacement.
- Keep the cutting deck clean: After each use, remove any grass clippings and debris from the cutting deck. This helps prevent buildup, corrosion, and uneven cutting. Inspect the blades regularly and sharpen or replace them as needed.
- Check and maintain tire pressure: Maintain the recommended tire pressure for your riding mower. Properly inflated tires ensure better traction, smoother operation, and even cutting.
- Inspect and tighten bolts and fasteners: Regularly inspect all bolts, nuts, and fasteners on your mower. Vibrations during operation can cause them to become loose. Tighten any that have come loose to ensure the mower's structural integrity.
- Keep the battery charged: If your machine has a battery, keep it charged according to the manufacturer's instructions. Clean the battery terminals periodically to prevent corrosion.
- Replace the fuel filter: Check the fuel filter regularly and replace it as recommended by the manufacturer. A clogged fuel filter can restrict fuel flow, leading to poor engine performance.
- Store the mower properly: If you won't be using your machine for an extended period, follow the proper storage procedures outlined in your owner's manual. This may include draining the fuel, stabilizing it, or storing the mower in a dry location.
