Hi guys so I have a Poulan PO17542LT
42 inch.
The drive belt needed to be replaced as well as the idler pulley. I replaced both however it's very hard to shift into other gears now. I don't know how to adjust the clutch/ rear brake assembly. I screwed with it and it made it worse. I don't understand what the deal is. Any help is appreciated it seems like there is too much slack in the belt now and it makes noise and if I tighten it up it's too tight.. I just don't understand! Should the drive belt always be moving? Or should it be like the deck belt wear when it's disengaged it has no movement.. Because right now it's always moving.
How do I adjust this thing?!
Thanks!
-Dave
42 inch.
Thanks!
-Dave
