honda sugre all time model GCV16LAQ
MUSTANG 2014
I HAVE A TROYBLIT WITH A HONDA ENGINE MODEL GCV16LAQ IT WILL NOT IDEL AT ALL I HAVE REPLACE THE CARB/ GASKETS FUEL HOSE AND I CAN'T GET IT TO IDEAL ANY ONE HAVE ANY INFO FOR ME I AM CLOSE TO FINDING IT A PLACE IN THE BARN
mechanic mark
OEM Parts : CyclePartsNation Honda Parts Nation Take a look at this list, locate your engine model with all numbers from your engine & see if you installed correct carburetor. A fuel strainer is in line at gas tank also, this needs to be changed also. Check air filter for replacement as well as throttle & governor springs, springs do loose their tension strength over time. Post all numbers from mower & engine data plates or stickers, thanks.
