Honda mowers and pine needles
Rawlings
I have had no problems at all with my Honda mower, and I have and will always recommend it. However, I recently heard about someone who had major issues when mowing around a pine tree. It seems the vacuum isn't good enough to pick them up properly along with the grass. Anyone else had this happen?
You can usually get high lift blades in almost any size... give that a try, unless you have a lot of sand, they should vacuum almost anything up... :smile:KennyV
I use my Honda HRR mower to suck up pine needles. If there is a lot sometimes you have to go over it twice, but it works pretty well. We cut our lawn so low that all we have to do is mulch the pine needles and it disappears into the lawn. That works great!!
