Export thread
Honda HRM215
#1
T
tom dorum
How do I check for a faulty coil? I am not getting spark. New plug & plug boot.
#2
J
jeff
first make sure that the coil is not being grounded somewhere. To check, unplug the ground from the coil and do a spark check. If you get spark, then you will have to find what is causing the ground wire to cause a grounded condition. If you get no spark, then the coil is the problem.
