Honda HRM215 governor problem
King72
I was given a Honda HRM215 lawn mower with a GXV140 engine by a friend because he no longer mows his own lawn. The mower had been sitting in his garage for a few years and he did not drain the gas after he last used it. When I got it, it would not start. After I cleaned out the carburetor I was able to start it. But it never ran right and would stall after running for 5-10 minutes. It looked like the engine was running too slow and I tried adjusting the throttle screw to no avail. I found some video on youtube about adjusting the governor to make the engine runs faster and decided to give it a try. When I tried to turn the governor arm shaft after loosen the bolt, it was so tight that I could hardly move it in either direction. After I tightened the bolt and restarted the engine, it was running so fast that it actually back fired a couple times and I could smell the unburned gas. The governor arm did not move and was always in the full throttle position. When I pushed the arm toward the carburetor, the engine slowed down. Looks like I might have messed up the governor inside the engine that it no longer controls the shaft. One thing I notice is that I can move the shaft and the arm in-and-out for about an inch which I think maybe the shaft is disconnected from some mechanism internally. I tried adjusting the governor arm shaft a few more times and could not get the engine to slow down. I am running out of ideas and any help is appreciated.
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
I'm going to move your thread over to our Honda section.
Hopefully, we can find you some advice.
Sounds like you might be right.
If it has been sitting for a long time the governor could have rusted solid, gotten gumed up etc.
It is a good engine & worth repairing.
Pull the engine apart and have a look.
The Honda manuals are not particularly good but if this is a first time pull down probably worth getting your hands on.
Parts diagrams are available from parts sellers and these are the most important .
Next most important tool is your digital camera, sitting on a tripod and a photo of each part as it comes off then reassembly is simply a reverse of the photos.
Because of all of the cheap knock off parts around, genuine Honda parts are now quite cheap so consider a new carb.
If not make sure you remover the emulsion tube and clean out every hole.
If they are not in spotless condition the engines run like poo.
