Honda HR194 - weak transmission.
c5vettster
I am new to this forum but I figured this is the place to look for an answer to a potential project I am thinking of undertaking this winter. The house I purchased came with an HR194 lawn mower. A really solid unit. Despite its age it starts on a first pull and the blade-clutch system is bee's knee since my front yard is wooded with lots of small branches. The mower has a two speed self propelled system. However, it is too weak to actually propel the mower. If I lift the back, it will spin the wheels but I can hold the wheels with my hand and there is little resistance. In other words, it is slipping badly. I have seen some youtube videos indicating that this may be due to transmission needed to be refilled with lubricant. Can the experts here confirm that this is indeed the case. I wouldn't want to go through the troubles of removing the axle if the clutch is burned since the internal parts are no longer available.
Thanks!
c5vettster
Oh how nice, it looks like the parts are readily available after all. What do you reckon is the matter with the unit? Is it the gears? It looks like I maybe able to buy a new one on ebay for $130. This may be cheaper than buying parts for it.
mechanic mark
Absolutely, I am also suggesting this manual if you plan on performing maintenance & repairs.
Amazon.com : Honda HR194 HR214 HRA214 Lawn Mower Service Repair Shop Manual : Lawn And Garden Tool Replacement Parts : Patio, Lawn & Garden
redmondjp
Crap, I was hoping it is something simple like a worn shift fork.
No point in further speculation until you start to properly diagnose the unit. It could also be a slipping belt - check for grass buildup on the drive pulley on the crankshaft.
c5vettster
Thanks, No I ruled out the belt, it is fits very tight, indeed.
javjacob
check out you tube for videos on all the Honda harmonies. There are a lot of transmission fixes on there.
