Question please, the fuel intake on my GX200 carburetor is blocked, any hints on how to unblock it? The engine was standing for a long time and I think its either rust or corrosion. I have tried to force fuel through, sprayed cleaner but no luck.
On the carburetor I can see the openings are blocked off by things that look like small bearings? Does anyone know what they are called and how to remove them. The one that is pointed by the red arrow seems to be inline with where the blockage is.
remove the tap.
Lay the parts out in order as they come off then take a photo.
once the seal on the tap is removed you have clear & clean access to the fuel line.
Replace the rubber gland under the tap lever as it will most likely be damages.
You can buy them individually or get a complete rebuild kit.
They come in packs of 10 but most mower shops will sell you a single one.
If you smile nicely at me you can have one for free provided you pay the postage.
