Honda GCV160 running rough
MattsLawnMowing
Hi all. Just joined and glad to be part of the community,
I own a relatively new honda GCV160 mower engine and I have been having issues with it recently. Ive owned it for roughly a year and during this period, I have used it extensively due to my small lawn mowing business within my neighborhood. During this time, I’ve kept up with oil changes and other obvious service items such as blade sharpening and spark plug changes.
The problems began this spring when demand for lawn mowing came back. When the engine is simply running and under no load, the RPMs fluctuate significantly. Not enough to call it surging exactly, but certainly not normal. It’s most prevalent when turning the lawn mower 90 degrees quickly or raising the front. It sounds like it almost dies and then comes back to life. This led me to believe that it could a be a fuel delivery issue. So, I replaced the gas cap(in case of poor venting) and removed the carb bowl to look for any sediment. The bowl turned out to be completely clean, but I sprayed carb cleaner into the jet of the carb nonetheless. In addition, I replaced the spark plug and ensured it was gapped correctly.
Should I check the valves? Ignition? Completely tear down the carb and clean it?
At this point, I’m really at a loss concerning the solution to rough-runnng nature of the engine.
Any bright insight is certainly welcome!
Thanks!
Tear the carb down and clean well.... In the emulsion tube you will see a slotted jet.. Take that out... Then there is a fuel nozzle in the tube take that out.....
That nozzle has tiny holes in it that needs a wire passed thru all the little tiny holes,,, Then a good shot of carb cleaner to clean even more....
There should be a screw on the body of the carb..... On the top side... Take that off,,, that is a idle port spray that out also.........
Let us know Mon Ami ~!~!
