Honda GCV160 rebuild questions
tkos115
I acquired a Honda HRR216VKA push mower that has a bent crankshaft. I got the mower for free from the old owner who hit a rock or something which ultimately bent the crankshaft. It is self propelled and came with a bag as well. It still runs well but shakes quite a bit. I swapped new blades on but no difference and I could see the wobble a bit when spinning the engine. The block and mower assembly look good, and the mower was always well kept.
Anyway, I have a new crankshaft, rod, piston and rings for it. As well as various seals, a new timing belt and cam. I would like to do a rebuild so I can retire my old push mower with a tecumseh lv195ea thats paid its dues and then some. Normally it probably wouldn't be worth rebuilding, but since I got it for free and its in great shape otherwise, I figure its still cheaper than a new one.
When I hone the cylinder bore, is there a certain hone type, or grit that would work best for this? Also does anyone have any suggestions for this rebuild or tips?
Thanks for any help/input
Be aware that the GCV style engine don't have a removable head and everything has to come out through the lower crankcase half which may make honing the cylinder challenging at best.
Very seldom would these engines be rebuilt. The juice isn’t worth the squeeze. Do a light hone to reestablish the crosshatching on cylinder.
I think these cylinders are Nicklsil coated cylinder, so do not hone. Stagger the rings so the gaps do not line up and use a large hose clamp lightly tightened with a narrow section from a plastic bottle to protect the rings. The piston and rings will slip right in with simple WD-40 spray.
Run plain SAE 30 oil for break-in and then 10W30 after that.
Some will disagree, but it may be possible to straighten the crankshaft to within a few thousandths. "Darryl Fixes All" channel on YT has a video where he demonstrates how to straighten a whanged crankshaft.
As far as doing piston & rings, if it was running well, did't burn oil, had good power, it won't run better with new parts. Actually using a ball hone or stones will add wear to the cylinder wall and reduce the effective lifetime. You remove a bit of metal when using the hone, leaving less of the Nikasil coating behind. If you had a GX, it would have an iron cylinder liner from the specs I have seen, but you have a thin coating meant to last for about one set of rings, two if you are lucky(edjumucated guess).
Honestly, I would not fiddle with the piston & rings if it ran well. You can lap the valve seats sort of, but not as readily as engines with detachable cylinder heads. I would try that just to clean the seats, but that's about it. Replacing the cam belt seems to be a good idea to avoid future failure.
With the price of replacement vertical engines as low as it is, spending a pile o' dough on pistons, rings, etc may be investing in something that should be good for a good while, but might not. Getting a bit lazy in my old age... so have fun! tom
ADDED: Just did a quick FB search. New GXV 160 for sale, tag on the gas tank, $150. Worth taking a look. What are the parts & gasket going to cost?
