I just recently purchased a used pressure washer with a Honda GC160 engine.
The engine appeared to be running great. However, on the second day of use, there was a loud metal noise and abruptly stopped the Honda engine.
Upon inspection, the rod on the intake valve had broken and it had punched a hole through the engine housing in two spots.
Any idea why this would happen? I suppose that there is no repairing this, unless I found another parts engine.
Thoughts? Pictures posted.
Pictures below: (you can where the valve busted through, it first busted through just above the spark plug hole.
