Honda 2417 engine surging on reduced power
Grassed-up
My 10 year old Honda 2417 suddenly just started 'surging' when on load. At idle it runs smoothly, with throttle up and driving, the revs come on and then fall back on a sort of 2 sec cycle. Air filter is clean,.......what could it be ?Has anyone encountered this ?
John G
Scrubcadet10
Moderator
Staff member
i would start by changing, or making sure your fuel filter isn't stopped up,.
Grassed-up
Cheers for that, scrubcadet !...........I've just ordered one, ....plus an air filter and an oil filter by the by !
John G
Russ2251
Surging ALWAYS indicates a lean condition.
Grassed-up
Dear Russ2251
thanks,.....I'll chaneg the filter ( easiest thing to do, I hope) If doesn't work, I'll spray carb cleaner in without disturbing jets,..................next thing would be run her on clean fuel plus Redex and hope to clean it out ............and finally, I'll dismantle , use carb cleaner, blow out and reassemble.
Regards
John G
