Hole in my frame
Koogan
First post: I have a small hole in my frame, or whatever the base of the mower is called that the engine sits on. I guess a rock made its way through. Any suggestions on the best way to repair? I figure duct tape might provide a temporary solution, but looking for something more permanent. Thanks.
Where is the hole? Many can be repaired.
If it is not near one of the engine mounting holes it can be repaired by cutting and forming a piece of sheet metal, then pop riveting it in place over the hole. Use steel pop rivets.
