high idle problems
jack15
I have a Z445 johnDeere zero turn with a 27HP engine. It will not idle up when you turn the blades on like it should, so it bogs down when you try to mow. What controls the governor on these?
Check the air filter by removing it.
Problem goes away = blocked filter.
