hi i have jd l111 wont start
primetime
my jonn deereont start it just clicks i have changed the battery and i also changed the solonide could someone please help:
WELCOME TO LMF!
It makes it easier to find a solution to your problem if we have model numbers. :smile:
Sounds like one of two things. First thing I would check are the wire connections. Make sure that they are all clean and tight, particularly the grounds. If you have a three post solenoid make sure that the base is fastened to a clean part of the frame, that is the ground. If that doesn't do it test the starter, by jumping it right at the starter, bypassing the key and solenoid. If it spins easily you will have to go back to the wiring. You said that you replaced the battery, but you would not be the first one to receive and bad or under sized battery. I recommend a battery with a minimum of 375 CCA for all of today's units.
