Help
Dhillbarn@gmail.com
I own a cub cadet tank m54 with 25hp Kawasaki last night I took the carb off to clean and got everything back together and it seems something is out of wack with the governor. Throttle linkage works fine while engine off but as soon as engine is on it will kick back to idle position and stay there no matter if I work the throttle or not. Need help thanks guys.
When you cleaned it you have dislodged the throttle to governor spring.
Thus when you pull on the throttle it does not pull back against the governor.
When stationary the governor allows the throttle to be wide open but once running the governor will always try to revert to a slow idle
