You are using an out of date browser. It  may not display this or other websites correctly.
alternative browser .
		Feb 6, 2019 #1
			N
		noelbp66
			Hi, I am starting to rebuild my mower but I'm not finding any numbers on the engine.  I've wiped off most of the grime, but no luck?  This is my first rebuilt, don't want to go too far until I find the correct info.
		Feb 6, 2019 #2
			M
		mechanic mark
		Feb 6, 2019 #3
			R
		Romore
			Do you have the original shroud that covers the flywheel? The engine numbers will be stamped into it.
		Feb 6, 2019 #4
			N
		noelbp66
			Yup...right there on the flywheel housing.  So much for my attention to detail!
		Feb 6, 2019 #5
		Boudreaux In Eunice La.
Go ahead and post the numbers..............
		Feb 7, 2019 #7
			R
		Romore
			That is the information you need, it is a 2 hp. Are you doing a tune up or complete teardown?
		Feb 7, 2019 #8
			M
		mechanic mark
		Feb 8, 2019 #9
			N
		noelbp66
Complete rebuild.  Currently seized up.  I have all the manuals now that I found the numbers.
