fitzerator
- Aug 24, 2014
- 1
- 6
I was mowing today with my John Deere STX38 and all of a sudden the blades stopped spinning. I found a wire un-attached going to what I think is the PTO clutch. It was crimped it, so with no way to uncrimp it I stripped it and then super glued it in. (Yeah, I know, I just wanted to see if it would work.) It worked for a moment and then the blades stopped spinning again. The mower knows when the PTO is engaged because it shuts off when I get off the seat when the switch it up but doesn't when it's down. So I think if I get this little plastic part, I can strip the wires and make a good connection. Anyone know where I can order this part online or what it's called?
