Mower deck Help please....
Captain
I have a John Deere F510 front deck mower. I took it out of the shop and the back of the deck is dragging the ground... What happened?
If you look below the clutch pedal area under on the deck there is a few brackets for the rear lift. You might have lost a clip and a pin might have slipped out.
Maybe this will help:
John Deere - Parts Catalog
Hi Timtractor,
Thanks for the advise. I checked out the back of the deck and sure enough the parts that hold up the back was missing. The carter pin had come off and all 5 pieces were gone... i have replaced them and im back to mowing... I appreciate your help...
