Help me out guys
Dhillbarn@gmail.com
I own a cub cadet tank m54 with 25hp Kawasaki last night I took the carb off to clean and got everything back together and it seems something is out of wack with the governor. Throttle linkage works fine while engine off but as soon as engine is on it will kick back to idle position and stay there no matter if I work the throttle or not. Need help thanks guys.
First, DO NOT POST in multiple forums. Will get very confusing for everyone. Second, post engine numbers and I might be able to find a Kaw service manual for you.
Boobala
YOU need help ..?? .. so do the folks here !! see example !! ( we ALL failed mind-reading )
GET INFO.JPG .... click on pic
Dhillbarn@gmail.com
Sorry I'm new to the site.
Year: 2009
Make: Cub Cadet
Model: Tank M54-KW (53AI8CT4050)
Motor: 25hp Kawasaki
We need model and serial numbers for the engine. 25 HP is the size.
