zman111666
- Mar 4, 2017
- 147
I have come across a few mowers that have the safety switch/flywheel brake hung up, like BlazNT said. When you pull down the bar before you pull the cord, make sure the switch is opening properly. Sometimes due to fatigue, the bracket will eventually bend enough to where the kill switch never breaks contact. You can usually correct this simply with a pair of pliers, and bend the part that holds the cable end back a bit.
