Help Cub Cadet carb linkage
KendallHarris
so I had to replace the carb on my mower.
19 HP Kohler
I am not at all good with mechanical stuff and managed to
pull both linkages free of the mower
Is there a diagram ANYWHERE that show how to reconnect to the control lever side??
Help
Scrubcadet10
Moderator
Staff member
Whats your model number? Should be located under the seat...
MowLife
You actually are going to need the engine model number off the motor itself.
KendallHarris
Thanks
I have a good idea now.
I am a much better nurse than mechanic
They both require patience and you never assume anything.
