Heavy 260Z hydraulic deck lift hose draining the tank
Halonfire
  • / Heavy 260Z hydraulic deck lift hose draining the tank
I have an 01? Gravely 260Z 992029
Accessory hydraulic deck lift hose leaking. Apparently, it has pressure all the time.
I don't use this feature. I have the parts to change to a manual.
Is there a procedure to block this off ?
Will it be nessesary to route the hose back to the pump or the tank?
One sure way to know you can block the pressure line is to remove the return line and run the engine. IF no oil return then block the pressure line; otherwise, you need to loop back the pressure to the return line.
Halonfire
Wow ! That's graphic. It's exactly what I needed.
Thank You !
Halonfire
Ports cut through chassis for these lines were too small. The forward port had the webbing pinched against the chassis. Had to cut ports with a torch. Both hoses rubbed & leaking due to hurried tie strap placement. Mark of real engineering at placement of immoveable parking brake lever necessitating a $40 wrench to remove Rt. control tower. Self tapping bolt in photo will be relocated 1-1/2" higher
