Have you ever used a Hunter MP1000/2000/3000 nozzle in a Toro popup ?
MowerMark
  • / Have you ever used a Hunter MP1000/2000/3000 nozzle in a Toro popup ?
At a plumbing store the salesperson demo'd these Hunter nozzles which screw into a Toro 6" pop-up. Supposedly they send out rotating streams of water for better coverage, less water waste (less misting), and reduced GPM. They were about $8 each.
Very tempting.
Anyone use them ? Reports ?
LINK -------> MP Rotator | Hunter Industries
MowerMark
Very tempting.
72 views and no replies.
I'm going to try them. Why ?
1. The Precision Toro heads do not go a full 90 or 180 degrees. Some edges of the lawn are drying out. These new one are adjustable.
2. When the nozzle sprays, one can see mist blowing away. So some water is NOT landing on the lawn. Water streams make more sense, if they accomplish even coverage.
MowerMark
I am using them, and have a report. Before posting about it, would like to know if anyone here tried them (or another root stream type nozzle) and what were the results?
MowerMark
Trial of Hunter MP Rotors and Toro TVAN (both adjustable)
No one has reported here, so I'll volunteer my experience. Tried the Hunter MP nozzles ($6 to $8) on 6" Toro popups on two lawns, each about 800 sq. ft. each. Not perfect head to head coverage, but close enough.
Toro precision sprays heads were on for ten minutes, so the timer was adjusted to 50 minutes for these new heads.
Very easy to install and adjust. The streams were quiet and pretty, and there was much less overspray. One gets the sense that there will be skipped areas the streams are sparse. Photographed the lawns at intervals, and used a moisture meter. Also, put out small cups in suspected areas so the water levels could be checked in the AM.
POSITIVES:
1. Pretty streams
2. Quiet
3. Less overspray
NEGATIVES
1. Definite small skip areas. Grass wilted, less rebound, moisture meter reading low ? zero (even in areas 3-8 feet from the nozzle). Got tired of supplemental hand watering those dry areas.
2. Filter looks finer, and when partially clogged which two nozzles did), the streams are reduced. Clogging never occurred with the Toro Precision Sprays nozzles. This is probably because the outlets for the MP nozzles are small streams, necessitating a finer filter.
3. If a leak occurs during the night, it will be for a long 50 minutes, not 10 minutes.
NEXT: Instead of going back to Toro Precision Sprays, have decided to use the $1.25 Toro TVAN nozzles Toro | TVAN Nozzles for one of the two lawns, and reduced the time to 10 minutes each channel for that lawn. Continued monitoring with small cups and the moisture meter. The TVANs were better than the precision spray because of getting a full 180 degrees. The fixed Precisions too often were 160 to 180 degrees.
Plan on changing to TVANs on the other lawn after seeing if they give better coverage than the Hunters.
MowerMark
Re: Trial of Hunter MP Rotors and Toro TVAN (both adjustable)
POSITIVES:
1. Pretty streams
2. Quiet
3. Less overspray
NEGATIVES
Forgot to add that both these nozzles (Hunter & Toro) are NOT good at nearby/close-up spraying. Toro could have placed a small slit inferior to the nozzle spray so that lawn nearby the head gets sprayed. Not everyone can achieve head-to-head coverage.
