Hard starting Craftsman Tractor YT4000
squirt48
My tractor has been a hard starter since I purchased it in 2013. I have replaced the fuel filter, changed the air filter, changed the plugs, charged the battery. Once I finally get it started it runs great, very smooth. Once the motor is warmed up it will start with no problem. It appears the throttle linkage is working because when I set the throttle to the choke position it moves all the way toward closed, and when the motor is started and I move the throttle to the run position the throttle linkage moves toward the open position. The tractor has a Briggs & Stratton 24 hp motor with less than 80 hours on it. Any help or suggestions would be appreciated.
mechanic mark
your valves need to be adjusted with engine cold, post numbers from B&S engine: model xxxxxx, type xxxx, trim xx & code number, also post model number from under seat.
