Looking for a new/used gas tank for my toro gts5. Mine is cracked at mounts and leaks. Thanks
K KeithGill Member Joined Apr 19, 2014 Threads 3 Messages 10 Apr 19, 2014 / Gts5 gas tank needed #1 Looking for a new/used gas tank for my toro gts5. Mine is cracked at mounts and leaks. Thanks
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,490 Apr 19, 2014 / Gts5 gas tank needed #2 Toro 1058952 TANK GAS
K KeithGill Member Joined Apr 19, 2014 Threads 3 Messages 10 Apr 25, 2014 / Gts5 gas tank needed #3 thanks but i have since learnerd i need a specific tank for my specific engine. A Suzuki. go figure.
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,490 Apr 25, 2014 / Gts5 gas tank needed #4 KeithGill said: thanks but i have since learnerd i need a specific tank for my specific engine. A Suzuki. go figure. Click to expand... Find Genuine Toro Parts Toro | Last edited: Apr 25, 2014
exotion Lawn Addict Joined Jun 24, 2012 Threads 66 Messages 3,444 Apr 27, 2014 / Gts5 gas tank needed #5 If you can't find a used one. Try looking at the newer commercial toro proline tanks and mounting hardware the deck style is the same and the larger tank might be nice. They both feed the carb the same amount and are gravity fed
