Hi all. I have a 6yr old 2348 husqvarna tractor. (Briggs Intec) It started smoking pretty good end of last season. Did some online research and decided head gasket. Made the replacement, adjusted the valves (a couple of times
and while it runs pretty well, after about 20 minutes, she smokes a little bit again. I noticed that in most of the videos I watched, the valves had caps on them, but mine did not. Is this normal? Any ideas of what I should check next for the smoking issue ? With these low hours, I cant see the rings being an issue .
Any thoughts would be appreciated.
Thank you all
Thank you all
