Gravely ZT34 rims
mike’s zt34
Hello, I’m looking for a rear drive rim for my 20+year old mower. A poor repair by previous shop allowed the holes for lug nuts to be stretched. The rim is no longer serviceable and Gravely has discontinued it. It’s a 8” rim that would install a 18x6.5x8 tire. No shops carry a match. Getting ready to junk the mower but everything else works fine. 4”x4 lug pattern. Can anyone help?
Could you give us some more information?
What is the model number and serial number of your Gravely?
Weld a steel plate over the lug nut holes. Redrill for your lugs. Easy right?
You need to watch that old TV show called Cuban Chrome. Was a car rebuilding show in CUBA. They have ZERO spare parts.
Another are my homies in Pakistan. They have a youtube channel called Pakistani Truckers. Both are off the chain, SMART resourceful people.
These are low speed rims/tires. I wouldn't care if it wobbled if you can't find a new one. Should be an easy repair.
Part number is 07100310
That "picture" looks like a front. Course if the rim is all he needs. There are a lot to pick from with this part number, IF it is correct for the OP.
That's a rear wheel assembly. A Gravely ZT34 is a pretty small residential zero turn. I'm sure that you are aware that mower tires of the same marked size don't always measure the same.
He could always call Ariens customer service and get more information. He would need to contact them for correct fit.
The original Gravely part number is 07100738. Gravely shows this wheel assembly as discontinued.
He could go up to a 18x8.5-8 however, he would need wheel spacers in order to get clearance between the tire and mower .
