gravely pm260z stalling
shyhippy
I have a gravely 260z with 300 hrs that runs for an hour or so then stalls.it will not start back up .let it sit for an hour and it runs fine.anyone else run into this issue???this has the Kawasaki 27 hp water cooled engine.
When it stalls next time
Drip some fuel down the carb throat or spray some carb cleaner in there
If the engine fires right up you have a fuel supply problem.
remove the fuel cap & try again
Problem goes away = blocked fuel tank vent
If it makes no difference
Pull the fuel line off at the pump, remove the fuel cap and blow back up the line
Problem goes away = debris in fuel tank plugging the outlet
No joy then remove the fuel cut off solenoid from the carb & check it's operation
Engine does not fire with the carb cleaner / fuel in carb = electrical problem
