Gravely 16 g deck noise
Pasture d
My Gravely 16 g has excessive noise in the 50" cutting deck. I have greased the outside zerks and have removed the center box cover and re greased it. Any ideas? Thanks
BlazNT
Remove deck belt from one of the pullies so the belt has slack. Turn all your idler pullies till you find the noisy one. If it is not that then start turning everything else till you find the noisy one.
mechanic mark
lube all moveable parts making sure not to get oil on belts
