I have a Grasshopper 721D with a Kubota engine. Last year it became difficult to start. It has gotten worse over time. The volt meter reads very low even with a strong battery hooked up to the system. When attempting to jump start it with my truck, I read just over 10 Vdc.
I have disconnected most all of the electrial systems in an attempt to isolate the drain on the system. Of course some systems isolate everything when you disconnect them.
Has anyone else seen a similar situation? If so, where should I focus my efforts?
