I have a grasshopper 1820 that was given to me because the engine is knocking badly.
I am assuming that it spun an main bearing, it has a briggs 18hp twin ii which was not the original so my question is should i look at repowering the mower, rebuilding this engine or just parting it out? If i can get it going it would make my 1.5 acre mow a breeze. The mower actually seems to be in good shape otherwise it actually cuts great still runs but i would assume its not far from destruction, is there an engine option that is a direct bolt in or fairly easy conversion?
