I have a Mountfield lawnmower with a side grass chute. The grass isn't getting pushed up the chute with enough force and therefore clogs at the bottom. Attached is a photo of the bottom of the mower. Do you see any obvious causes? I know there are a few holes, so do you think this would affect the air pressure and movement enough to cause the problems I'm having?
Grass even clogs up at the bottom of the chute even when the mower is on full power, cutting short grass and I'm going at a snails pace. Any help would be much appreciated.
Thanks
Thanks
