What approach do you guys use when grass is outgrowing your mowing schedule? This time of year, with all the rains and the fertilizers being put down in the Southeast, I start having an issue with my mower leaving clumps behind. My mower is a 54" Fas Trac SD with a 26 hp Kawasaki, and I have a mulching kit on it. My first job I told the guy I requested a "per cut" rate as opposed to a "per week". I guess that is the standard? Anyway, I start out in the Spring at a 7 day interval. No issue. But as the grass grows faster my settup just doesn't seem to cut without leaving some clumps. It's basically not mulching it fast enough. What do you guys do? Tell the customer that we are looking at a 1.5 to 2 time per week in the growing season? Do you slow down your mower travel speed to give it time to mulch? Do you raise the cut, cut it and then lower it back to original setting and cut again? Right now I'm mowing my yards at 3.5" and most if not all are Tall Fescue grass. I'm trying like heck to keep my mulch blades sharp and my deck clean before I start cutting. Should I scrap the mulch idea and just go to a straight side discharge? A 26 hp Kaw on a 54" SHOULD be manly enough to do what I'm doing shouldn't it? I plan on moving my cut up to 4" by Summer so I guess that may help, or does it really help? It's still growing at a fast enough rate that I'm getting a lot of grass to cut each time. I also know that the rule of thumb is that you should not remove more than 1/3 of it's height each cut. Do you guys follow that? If so, it looks like to me the only alternative is go on an every 4-5 day cut as opposed to a standard once a week cut. How do you guys do it. Any other tips would be appreciated.
Did you ever figure it out? I would say just do a double cut, the same height as the first cut and see if it mulches the clumps
#3
jekjr
We cut tremendous amounts of bahia grass. Most people want it cut on a two week schedule. It is not only going to leave clumps but at times you could rake it and roll it and use it to feed cows. It was a tough season.
I tried mulching commercially years ago and I ended up scrapping the idea. It's just too much to work around if you have a full schedule IMO. Just too many times when the conditions aren't suitable for mulching...too long, too lush, too wet etc and having to go painstakingly slow at times and/or manufacturing the dreaded clumps and tire ribbons.
These days I run Gator G5 or G6 blades discharging and will raise the deck up a 1/4 or 1/2 inch and make a second pass over any heavy windrows. I'd rather have windrows than clumps any day! I do have the ability to bag as well, but in many cases that just isn't practical. I generally only bag during spring and fall to pick up debris and around swimming pools or beds that I can't avoid throwing clippings into otherwise.
